Terryallan
Jul 27, 2014Explorer II
I realize weight may not be a consideration. However. IMOP the APEX has two features that put it ahead of the Puma. First is of course weight. the Puma comes dry at 8,137 Lbs. The APEX is dry at 5980 LBS. a difference of 2197 LB. However the Puma does have a much higher carrying capacity.
the other thing is that the Puma is ridged aluminum siding. The APEX is AZDEL covered with fiberglass. The APEX will be MUCH, MUCH easier to keep clean, and to clean after it is used. Easier to wax as well.
44,068 PostsLatest Activity: Jun 01, 2026
