- mwb521ExplorerI have a Jayco 1206 and I can't see a model number on the fan. The crank is a cross connected to a small rod. The handle hangs down further than it use to and it is hard to turn.
- beemerphile1Explorer
mwb521 wrote:
Any suggestions on where to find insight on replacing the exhaust vent/fan in my PUP?
All the insight you need is here but we need information. Brand and model of RV, brand and model of fan, and what is the problem? - DesertFiverExplorerI changed the bad fan out in my 5th with a computer fan. Friends see it and now changed theirs out. Inexpensive (cheap) and easy to hook and easy to find used. You can buy new at Radio Shack or a computer store but that costs more. My friends and I have never had a problem with a used one in more than 15 yrs. Bottom line: Quiet, moves a lot of air, easy to install and cheap. :)
- RimCountryExplorerI just installed one of these in my Viking pop-up... it fit the existing hole, tied in to the existing wiring, and works like a charm!
Fan - Tastic Vent® Model 4000
PS: Low silhouette allows me to see over it in the rear-view, too! - TerryallanExplorer IITry your nearest RV dealer. They should have what you need. The Roof RV vent fan is pretty generic. They all have pretty much the same thing.
- rrupertExplorerPlease add some additional information about what your existing fan is and why you need to replace it. What is the popup make and model?
44,030 PostsLatest Activity: Feb 04, 2025
