RVCamperDan's avatar
RVCamperDan
purchase advise: used Jayco x213 or new Jayco x213?
Hi all,
I have been lurking for sometime and learning a ton from the wealth of knowledge this forum provides! We are finally ready to purchase our 1st travel trailer and are stuck on a decision I hope you can advise on: purchase an '09 or '14 Jayco x213? We are pretty much sold on this layout, the question is are the tradeoffs of used worth the price break? A few more details about the two trailers:
09 jayco: pros $8k less than the new one, cons: I am tall and the slide out bed (which goes side to side across the trailer) is borderline long enough for me, the tanks FW- 30g/ GW- 30g/ BW- 22g, the top bunk is 10" narrower than on the new one, and various small item things that will need to be fixed (e.g. door strut $25). otherwise the unit is in really good shape, it has been stored outside, but has been used very little.
14 jayco: pros- tanks FW 46g/GW 30g/BW 30g, 2 year warranty, wider top bunk, slide out bed is a king sized and goes long wise down the trailer so as not to confine me with a wall... cons: price is +$8k, insurance and tax will be more as well.
We are not rolling in money but we can afford both units. The question is as an RV newbie I really don't know how much those pros/cons will matter: can you advise? My kids are small now, but I plan on having this trailer for long enough for them to get big (~10years). I should also add most of our camping will be done at places with none to minimal hooks ups- e.g. state parks. hoping to buy soon
thanks for your help!
TV- 06 double cab tundra
TT- ?????
  • and you can always carry a couple of 5 gallon collapsible jugs in the shower if you think you will need more.
    bumpy
  • I think most of our trips will be 3-5 days with no hookups, but just guessing here without actually owning a trailer :)
    TT- ?????
  • RVCamperDan wrote:
    thanks for the responses... I hadn't thought about the roof or the slide problems. how about water capacity- is the difference of 30 vs 46 freshwater capacity noticeable?
    TT- ?????
    depends entirely on how you use your RV. go out and boondock for ages with no hookups? wouldn't make much difference to me.
    bumpy
  • thanks for the responses... I hadn't thought about the roof or the slide problems. how about water capacity- is the difference of 30 vs 46 freshwater capacity noticeable?
    TT- ?????
  • I responded in your other post. get new with warranty, not one with an older EPDM or TPO roof.
    bumpy
  • RoyB's avatar
    RoyB
    Explorer II
    I would really look close to the 2009 model as this was the last of a series that had some leak problems associated with the very large rear bedroom slide. There was also some under-sized slide motors originally with this model.
    The 2010 models and up really fixed a bunch of these problems.
    Another problem associated with the older X213 units was the level of slides over time. After awhile the slide would not be level and when you brought it back in it may tear your upholstery on the couch seats and the dinette seats. That also was addressed with the newer models...
    I really haven't tried to follow the newer X213 units to see how they are performing to date. Was very very interested in getting one in the 2010 time frame and did alot of research on them at the time.
    I love to idea of the large bedroom slide the X213 has.
    May not be any issues now but the 2009 and earlier models sticks in my mind as being problem childs.
    The 2010 and up model moved to side windows on the large slide verses the one large rear window the 2009 had also.
    Roy Ken
