mlayton
Jul 06, 2013Explorer
Thanks Passin Thru. Are you saying to entirely replace the exsisting hitch and replace it with one rated to 12000 lbs and then add the weight dirstributor? I just checked and the numbers I quoted before of 890# tounge weight is off the Ford site, for our hitch taking into account that we have an extended cab.
So with a different hitch, that can better support the tounge weight (if I'm reading the specs correctly) means the truck itself is rated to pull a max of 8700# which we would be in range for with the heavier JayFlight.
