mlayton
Jul 06, 2013Explorer
Thanks "Chuck & Gail", like I said - we are trying to learn and understand better so I appreciate the time to answer! So if I read correctly, we CANNOT consider the heavier JayFLight with this vehicle. You are saying we should be OK with the lighter weight version though. If we load up the truck with just what would normally be in it for a trip (dogs, kids, gas, etc. but likely minimal other "stuff" because it's all in the TT), go weigh just the front two tires - get that number and check the front axle rating then pull forward to just the rear 2 tires and get that weight and then add on the 890# and see if we are in range of the GAWR. It sounds like we need to buy the 2013 Towing guide from Ford to double check our specks. Thanks again!!!!
