Golden_HVAC
Apr 05, 2015Explorer
2011 and later have a much quieter engine and more power. 2005 and later has a LOT of cargo capacity, so the dually after 2005 can carry about 5,000 pounds, while a 2004 and earlier are less than 3,800 pounds.
I agree, you should avoid the 6L and 6.4L - even though they have some great add on's that will make them a lot more reliable, yet you never know if the used truck you are driving is only a few miles from failure, or if it will go a lot further.
After a water coolant filter is installed, and changed at 800 miles, 3,000 miles and 9,000 miles, the coolant becomes pretty clean, and the oil cooler failure is much less likely, when the oil cooler plugs with debris, then the exhaust coolant filter gets no water, and it cracks, and then you end up with water in the engine. . . $15,000 later and you have a engine (new one) that is good for 100,000 more miles or so. .
The 7.3L was a great engine, but sadly most will have well over 200,000 miles on it. That is like buying a boat with 5,000+ hours on the engines. Besides the engine and transmission needing attention sooner or later, there are steering problems, and other suspension things that will wear out too.
So if you can find a dually F-350 that has less than 200,000 miles on it, it should be a great deal. Probably something much more reliable would be a 2011 and newer F-350 dually.
Or look for a gas V10 model. They are also reliable, but will consume a bit more fuel. Depends on how many miles you plan on traveling each year. If more than 10,000, you might spend more on the V10, but less, and the $45 oil changes are pretty nice, as well as lower cost per gallon fuel. It is rated at 26,000 GVWR in the motorhomes, and 30,000 GCVWR in some of the trucks.
Good luck!
Fred.
Good luck!
Fred.
