evanrem
Oct 26, 2017Explorer II
theoldwizard1 wrote:evanrem wrote:
This would work
That is way over the requested weight limit with a GVWR of 9500 lbs. You are never going to get 3 slides and be under 8000 lbs, loaded.
Also one person in the bunk room is sleeping in the middle of the floor.
There are only three bunks but the bottom can fit two small kids. There is also a another bed mat that is stored under the bottom bed that can be used to put on the floor for a 4th sleeping area. Depending on features you should be able to pick it up between 27K - 33K depending on features.
