Nov 12, 2020Explorer II
I'm sorry I got your hopes up only to tell you this converter won't work for your application.
2 problems:
It's only good for 360W at 12V
If you do indeed have a smart charger, you can't replace it with this converter and expect it to work without developing additional circuits. The BMS tells the charger what to do.
We were debating if you should without determining if you could.
FWIW: I have 3 of these converters in use for different purposes without issue. One boosts my TV voltage to my FW battery to a constant 14.2V to recharge my battery while driving if needed. I have a toggle switch to remove it from circuit if not needed. Another in my boat to recharge my 24V trolling motor battery bank. The third runs a 48V hoist. I have a fourth on the shelf as a spare but haven't needed it.
2 problems:
