JoeChiOhki
Sep 03, 2020Explorer II
JimK-NY wrote:
What are you planning on running with this pure sine wave inverter?
Mostly the same stuff we were running off the Modified, small electronics (TV, roku, laptops, low load stuff) and the 2-way fridge while driving (We have a whole change over circuit that switches a block of outlets between the short power outlet and the inverter circuit.
The original inverter was a 400watt, and did the job well, and the fridge that it was powering is now in the new camper, so the work load will be the same, but I want to clean up the power as the new camper has built in USB charge ports in the outlets by the dinette and I wanted to make sure we didn't damage small devices by continuing to use a modified type.
