bondebond's avatar
bondebond
Pushing your PUP around by hand
I started out with a Jayco PUP that was fairly light-weight with a 10 ft. box. After unhitching it, I was able to push it around in the garage on the smooth, level floor to position it where I needed to finesse it out of the way.
Well, fast forward to today with a PUP that is about 3,000 pounds instead of the 1,700 pounds of the previous unit and that task has become much harder to do, to the point I just about can't do it. I purchased a heavier duty tongue wheel to deal with the increased tongue weight over the included wheel as that was definitely not workable. Still, it was a major effort to move and navigate the PUP around.
However, I decided to take the wheel for the tongue jack apart and to lubricate every contact surface - the sleeve bearing and axle, the ball bearings, where the body pivots on the bolt, etc.
That was a major improvement in how it now works. Night vs. day. I have to actually pull back to stop the momentum now. Technically, I would say that it is easier to move this one around versus the first one, simply by liberally applying grease to the tongue wheel components. I did notice that the heavy duty wheel uses a large bolt to hold it together that allowed me access to the ball bearings and other surfaces and the standard duty wheel had a rivet holding it together, making access more difficult. I fear too many of the standard issue wheels are like the second one.
I finally picked up an old bathroom scale so I can weigh the tongue to see exactly what I'm dealing with. For some reason, the DW doesn't want me using the glass top digital bathroom scale from the house...???
So if you're one who is able or would like to be able to move your PUP by hand without using other methods, try lubricating the tongue jack wheel.
And I am still on the hunt for the rest of the components to make my own electric trailer mover. No rush now, though.
  • If you actually knew the situation I was dealing with, you might not speak so disparagingly.
    Once it is in the shop, I move it over out of the way to make more open floor space for other projects. I put the rear of the PUP where it needs to be for the process before unhooking from the TV and then swing the front toward the wall and sometimes need to rock it forward and backwards to get it ever closer to the wall.
    There's no possible way a TV could do what I do by hand but thanks for the suggestion. And I'd rather not jack it up to put it on wheel dollies every time so I can slide it sideways. It doesn't take a lot of work to accomplish this - 5 minutes at most. I would rather not have to add a wider door to the shop just so I could back it in right next to an exterior wall.
    I am personally aware of people who rotate their PUP 180 degrees to be able to squeeze the PUP in their garage with the tongue pointed into an alcove. I do not think that would be possible with many things anything other than a PUP. I'm just trying to provide a friendly tip for those who do utilize the jack wheel.
    With a high wall PUP and an axle flip, I pretty much have the same visibility issues as TTs. The roof of my PUP is taller than the roof of the TV. It is not as tall as a TT but I lost the ability to see over it from the rear view and side view mirrors as when I had a standard wall PUP. My choice, sure.
    So, swinging back around, IF you are someone who actually can or wants to use the tongue jack wheel on your PUP, a little lubrication can make the job easier.
  • OR you could practice backing so you can place the trailer where it's needed with the tow vehicle. That's what nearly EVERYONE with a full sized trailer does. You'd at least have the advantage of visibility when backing and most of us don't have :)
    Good luck / Skip
  • I'll pass on those. I don't really want one even though I play around with the idea. I can't always take it with me and I am into the reduction of "stuff" to haul around. The jack wheel is fairly compact as far as that goes. And as mentioned, I would be making an electric, motorized version of that if I went that route.
    Just the little bit of maintenance above has really put the desire for a trailer dolly to bed for now anyway, which was my intended purpose.
  • And I am still on the hunt for the rest of the components to make my own electric trailer mover?
    No. Just buy a trailer dolly. Hundreds of them to choose from including one that folds up so you can take it camping with you! :B
