Bedlam wrote:
265 and 285 width are available but not as common. The problem with these size tires is that they are taller and may not clear the wheel wells without modification to well or suspension and few rim choices are available in widths recommended for these tires. These taller tires will also raise your CG and change your ratios to the ground, so those factors should also be considered. The 245's are typically 33" tall and the same height as the premium tires offered by the OEM, so fitment and handling are usually not an issue.
Exactly. I wouldn't be able to clear a 265 without longer control arms and a lift, not exactly the towing route IMHO.
I like the narrower tire, and always have. My winter/hunting tires are a 255/80R17.
