deserteagle56's avatar
deserteagle56
Explorer II
Jun 27, 2017
Puzzler for you electrical gurus....
A year ago I bought a 12v LED light strip (18" long) and mounted in the van I use an another RV. I like it so much I bought a couple more of them to use to mount in my Bigfoot pictured below. These light strips are specifically designed to use as under-counter lighting in RVs. This morning I tried to mount one of the light strips in the Bigfoot but I cannot get it to come on and cannot figure out why. I removed the OEM light fixture (designed to use a #1141 12v bulb) to access the wiring and spliced into it. Nothing. My test light tells me there is power and the OEM fixture works fine. If I connect the light strip directly to a 12v battery just by touching the wires to the battery posts it works fine. So what is different with the power going to the original light fixture?? What do I have to do to make this thing work?
Thanks in advance!
