ticki2
Jun 28, 2017Explorer
deserteagle56 wrote:This puzzles me , the voltage should be higher on converter than on battery alone .
There is obviously something different with the power coming via inverter (shore power) versus battery power. I know I said that the voltage is the same but there is a minute difference and I wonder if that's enough to cause the problem. When on inverter the multimeter shows the voltage constantly changing a tiny amount, in a range from 12.9 to 13.1 volts. When on battery power the voltage is rock steady at 13.23 volts.
Whatever the reason, as least I'll be able to use the LED light strip on the majority of my camping trips. Thanks to all who responded.
