2013 lance1172. Side where dump rods are is pulled out. Can put your hand right inside .All road grime goes into the out side shower and pull on and off. Door holder snapped off. Black water tank wont register.Pass thru window leaks bad.Filings from where they drilled and screws and bolts most everywhere.Fridge freezer door crooked and has been shimmed. N0 paper work on the gen. heat vent cover falling off.Screws not into anything.Must be more but only had it out once.
