Side where the The dump valves and power pull on and pull off and Out side shower. The camper outside panel is pulled away. There is a seal and you can stick your hand inside with out opening the door. Was at the dealer for scratches on the bed skylite and the to replace all the wood around the rear sofa that was beat up. They called me and said it was there.Drove down and it had not been shipped. Screws from the heat duct arnt hitting nothing. The dump tank valves were marked wrong. No marking for city water or black tank flush. But I did fix the pass thru window leak. Cable pulled out of the tv. Bought a new one at radio shack. It 200.00 rount trip to the dealer. Been there twice. So if anyone thinks im complaining I SURE am.
