tsbelue wrote:
I only get 10-12mpg towing and up to 17 unloaded with my 5.9 CTD but it has the 4.10 gears. It is the 235hp standard output. I dont expect it to get diesel mileage, that's not realistic. I would get a 6.4 with the 4.10 gears so it would tow the best. I work for Toyota here at the Tundra engine plant. The mpg for the hemi is not that different from the 5.7 Tundra engine. If my camper was lighter I would buy a Tundra cause they are good and that's where I get my pay check. I like the Ram and I think it fills my needs but just wanted to hear from you guys that have already tried towing with them. Thanks and keep sending your thoughts.
Just read your profile! You will not be happy with a 6.4, you are likely over 300 hp and about 650 lb. ft. If you were stock the 6.4 would be an improvement, but the towing beast you have it will be a let down.
