Chuck_thehammer
Mar 22, 2016Explorer
you are correct.. the startup power is much higher ...
in the AC world... large startup is common in power devices.. as its only 5 to 10 seconds... could be 3 times the running watts.
or
your battery bank is dropping voltage at the startup...
volt meter at inverter to see..
then volt meter at battery bank..
or
