fairfaxjim
Mar 23, 2016Explorer
pianotuna wrote:
This is what is balanced and best for twin twelve volt batteries.
As it often doesn't cost a dime more to do this, I think it is worth the trouble.
The inverter is too far from the battery bank and the wire is too small.
Little things snowball when you have low voltages & high amperages. Make sure the jumpers between the batteries are as large as the main cables.
I would recommend a battery bank of at least 4 6 volt golf cart batteries for successful inverter use. More if you plan to do longer heating loads.
