tfirma's avatar
tfirma
Question about Battery Load / Inverter Capacity
Hello everyone!
I'm almost embarrassed to ask this, because I've read so many articles, posts about the topic - but I STILL can't figure it out. Here is my scenario :
I have (2) 12v AGM batteries wired in Parallel. I have 4 gauge wires coming off of one of the batteries, about 9 feet, to an inverter. First, I was using a PowerBright 1500W (3000 peak) inverter. I tried to run a Keurig Mini (1350W requirement) and then a very small heating device (1200W requirement) Both of them "tripped" the inverter and wouldn't. I wasn't totally shocked - especially with the Keurig, I know that the startup time to heat the water may exceed even their "peak" limits since it goes longer than a few seconds.
After talking to someone on the phone from PowerBright, they said that the inverter wouldn't handle the Keurig, but that the 2300W model would definitely handle it. So I purchased one of those. Same problem.
I've checked all of the obvious things (the Keurig definitely works, all connections are tightly connected, and the inverter DOES work for other devices, with smaller wattage requirements)
This leads me to what I'm wondering/thinking. Is it POSSIBLE, that my BATTERY BANK is what is limiting the running of the Keurig? I can't seem to find a simple equation or explanation as to how to calculate what load the inverter can handle. Meaning.... I *think* that even though the inverter can handle 2300 Watts - if the battery bank can't handle it... it doesn't matter what size inverter you have. I would think that 2 AGM (34M) Interstate batteries could handle a minute at 1350 watts draw...but perhaps not, as this is the only factor that I can't seem to clarify and would certainly explain why neither inverter worked!!
I'm hoping someone here with good experience/knowledge can please enlighten me. I'm not sure how else to test without adding more batteries (and I'm not even sure that's a logical solution). Thanks in advance for any help you can provide!
Thank you,
Tom
  • tfirma wrote:
    While a larger capacity inverter would certainly come in handy when I'm boondocking, I suppose there are other ways to make coffee, etc. without trying to jump through so many hoops.
    Well there's certainly no need to use a Keurig Mini that draws a whopping 1350 watts just to make coffee. :E We've been using this 4-cup Cuisinart Coffee Maker I bought at Sears which is rated at 550 watts and measures an actual 505 watts when powered by my 1000 watt PSW inverter. You also mentioned in your original post a "very small heating device" that requires 1200 watts but I'm trying to imagine what "heating device" would be worth running when you don't have shore power? :h
  • SoundGuy wrote:
    smkettner wrote:
    Cable Gauges
    When connecting the inverter to a battery bank use the thickest stranded
    insulated copper wire available in the shortest length practical. If the inverter &
    the battery are positioned within 4 FT of each other, a minimum of #4 gauge
    wire should be used to make the connections. When the distance between
    inverter & battery bank is 4-6 FT, a minimum of #2 gauge wire is required.
    For the OP's application I'd agree cable gauge he's used is insufficient and cable length too long but I'm not sure I'd agree with this as a generalized statement. When I wired in my own 1000 watt inverter I could only find at reasonable cost 4 gauge wire so that's what I used. My intention was to have each cable no longer than 4' but because I wanted to protect the inverter from the elements by locating it in the trailer's front pass through storage compartment the runs from the battery to the inverter ended up being 6'. However, according to this Blue Sea DC Wire Gauge Chart I'm well within spec for up to a 100 amp draw. Typically though I wouldn't draw any more than 70 amps at most so although I had considered replacing those 4 gauge cables with something heavier I'm thinking now that I'll just leave it as is. I wouldn't doubt however that root cause of the OP's problem is that he's used cable that's too long and of insufficient gauge, especially when just 2 batteries of unstated capacity are most likely marginal for such a high draw application.
    Yes you can engineer for the minimum and then use just half capacity and get by fine.
    The manual I quoted is for the OP's inverter and should include not only running at max rating but also to consider getting full surge performance.
    The OP is using the inverter near max. No reason to shortcut the OEM install instructions.
  • smkettner wrote:
    Cable Gauges
    Not sure where we disagree. :h Clearly the OP is using cable that's too long and of insufficient gauge for the load he's intending to power, not to mention he's attempting to run these heavy loads with just 2 AGM battery of unknown capacity. Doesn't make a lot of sense to me and now he's asking why it doesn't work? :R
  • SoundGuy wrote:
    smkettner wrote:
    Cable Gauges
    I'll never understand people that have to be insulting in their "responses". However, if it makes you feel superior to question the intelligence of sincere questions in these forums, have at it.
    Just trying to stay focused on the OP.
    You called out my quote from the manual and seemed to imply it can be ignored or there is a better system(blue sea) or if big wire is too much $$ just install what is affordable.
    A simple "+1" is fine if we agree. Or just state your thoughts independently.
    Sometimes messages just get crossed up a bit on the internet.
    Cheers ;)
