hawkeye-08
May 18, 2015Explorer III
Old-Biscuit wrote:hawkeye-08 wrote:
If conditions are perfect, you can leave the valve open. IIRC, 1/4" drop per foot will keep the solids and liquids both moving. If it is steeper than that, the liquid will leave the solids behind and you will have a plugged up mess eventually. This includes in the holding tank and pipes and hose. Since conditions are never perfect, best to keep valve closed until you have enough to dump (and flush if you want) and then close again after dumping.... for me, I never want to have to work on it, it was bad enough the previous owners of our trailer left a rock hard pyramid that took lots of water and several trips to get cleaned out.
That would pertain to sewer plumbing in a S&B house
RV waste tanks..........poop goes plop directly under toilet and liquids run away from poop plop pile.
Just like an outhouse, vault toilet, pit latrine, squat toilet.......
I wonder how that stuff gets out of the tank then.. don't need no stinking slope.
Thanks for proving my point. You really don't want the liquid to get away, you do want to retain it and let it all drain together...
btw, I have never seen a vault toilet with drain at bottom with valve.
44,056 PostsLatest Activity: May 04, 2014
