RAS43 wrote:
edbehnke wrote:
you shouldn't have to top it off at all. if a little low just add water.
Not a good answer as adding just water will weaken the strength of the coolant which can cause problems. I think Ron has the right answer-have the dealer top it off as it is still under warranty.
Sorry, but this guy has (edbehnke) has the best answer (next to mine of course LOL).
Coolant is in a sealed system and is non-evaporative within that system. If you are losing coolant, or the amount becomes low, then you have a leak. Not all leaks are bad. If you had to top off your vehicle once every 6 months, then you have a leak that's not bad. You'll spend a lifetime trying to find a leak that small.
However, back to point. If you have a leak and need to top it off in order to get somewhere (like home or the service station), then feel free to use plain ole tap water. Why? Because you have to fix the leak. In order to fix the leak, you're likely going to end up draining most of the coolant anyway, unless the leak is on the upper-end. Coolant mix precision isn't so important that being slightly off will hurt anything. My 1 ton truck takes about 5 gallons of coolant. A little mix precision error won't be the end of the world.
Its not worth having a $15 jug of dexcool sitting on your shelf for the "maybe" scenario where you have to top it off. Under warranty you say? Then take it to GM and make them chase the leak down. Considering that coolant is a poison and only takes one drop to kill an animal (and is severely toxic to humans), I don't like taking the chance of having it sitting around. Even unopened plastic bottles can develop a leak just sitting there.
For a fun fact of the day, my 1/2 chevy with 5.3L engine has about 205K miles on it. I've NEVER touched the coolant in it. Never added a drop, never flushed it, nothing. Some would suggest that this is negligent on my part. I say to them, it doesn't overheat and doesn't leak and doesn't freeze up. I'm not going to fix something that's not broke.
