- bid_timeNavigator
LarryJM wrote:
No they put GY Marathons on because they are cheaper, quit the opposite of what I said.bid_time wrote:
Did I sum that up correctly?
NO, NO, NO ... you are so far off it's hopeless. But, I also bet you believe what every trailer and car saleman tells you too and since a HUGE number of OEMs use GY Marathon ST tires you believe those are the best tire going since they wouldn't put something on that isn't the "cat's meow" on a trailer would they. :R
Larry - LarryJMExplorer II
Larry - hddeckerExplorer
djsamuel wrote:
Is a new rear seal required every time the bearings in the EZ Lube hub are removed and hand packed?
Yes, unless you have some way of getting the old seal out without it becoming misshapen.
Also the seal is going through untold numbers of heat cycles that take their toll on the rubber. It gets hard and becomes much easier to damage when putting the drum back on. - HuntindogExplorer
djsamuel wrote:
I would. It also is supposed to be a special double lip seal... A regular one will fit, and that may be the cause of some of the failures that occur.
Is a new rear seal required every time the bearings in the EZ Lube hub are removed and hand packed? - bid_timeNavigatoroops -d-d-d-double post
- bid_timeNavigatorSo let me see if I got this right. A manufacturer goes through all the extra expense of machining holes, adding threads and installing grease zerks; and in the end a lot of people are sitting along side the road with frozen wheel bearing and expensive repairs. And what does the manufacturere do, he keeps on putting the extra time and effort in to manufacture e-z lube for at least 15 years and counting.
And now you want me to believe the manufacturer either doesn't know about all these failures; or they just want to continue to spend all that extra money on something that doesn't work and is causing a lot of problems.
And I must say, I just haven't seen the bearing failures sitting alongside the road in my travels. And secondly I haven't any first hand knowledge of any.
I pull my drums and check my brake shoes when I think it's time. But these people that think e-z lube has no useful purpose, well real life doesn't seem to be supporting your views. - djsamuelNomadIs a new rear seal required every time the bearings in the EZ Lube hub are removed and hand packed?
- westendExplorer
Larry wrote:
The truth!
In any event any minor mistakes still doesn't change the bottom line that this feature is not worth the effort or HUGE amount of grease and is frought with potential downsides, blowing out the grease seal only being one.
I'm now old enough to barely remember packing a lot of axle bearings. Back in the day, all cars and light trucks had serviceable front axle bearings. There were no Bearing Buddies or EZ Lube axles (well maybe I just didn't see any). Some trucks had a zerk on the dust cap.
The overheating-from-hub-filled thing I've never seen. I've seen many hubs packed with different layers of gnarly grease and water trapped among them but most have the bearings working alright if the bearing was properly packed. This tool takes all of the guess work out of packing bearings. If done on a reasonable schedule and using today's modern greases, there is little need for adding grease into the bearing, IMO. - AH64IDExplorer
BB_TX wrote:
As far as overheating due to being full, it does not happen. I have towed mine thru Texas/NM summer heat of 105+ and the hubs do not get hot. Myth.
There isn't a way to check the bearing temp with everything installed. With an overfilled hub the hub will be cooler than the bearing and it's the bearing temp we are concerned with. It would be very easy to get a false sense of security if the heat cannot leave the bearing as fast.LarryJM wrote:
Unfortunately the Timken website in their FAQs Timken FAQs specifically state:
Always follow original equipment manufacturers’ recommendations regarding grease purging and correct replenishment amounts
so Dexter's information and directions trump anything Timken might say to the contrary.
CHECKMATE:p:B
Larry
DOH :B
Like I said, in the end do what you are comfortable with.
One thing that may help over-greased bearings is their size.A 5,200lb Al-Ko uses the same bearings as the 7K unit, and the inner is also the same as the 8K. So while a 5,200lb axle may be at it's limit the bearings are far from it so less heat is generated in the first place. - NanciLExplorer III am on my second trailer with the EZ lube, and that is all I use.
I have never had a problem.
As soon as I see the new grease coming back out I stop.
I think it is imperative that no matter which method you use, you should do a walk around at every gas stop or pit stop and feel each hub for overheating
The EZ lube bearings are put there to make life easier and a lot less messier and that is why I use them
Jack L
44,071 PostsLatest Activity: Aug 16, 2026
