AH64ID
Aug 22, 2014Explorer
As stated the grease goes to the inner bearing, and then the outer bearing thru heat and hub design.
Ez lube axles make it too easy to over grease the bearings, which can be as bad as under greased.
Many recommend ignoring the zerk fitting and just doing proper packing annually. Even my axle manual states that the ez lube fitting does nothing to extend the standard packing service interval.
44,067 PostsLatest Activity: Jun 05, 2026
