BB_TX
Aug 22, 2014Nomad
Dexter EZ Lube
Grease goes thru the port to the rear bearing, thru the rear bearing to the center of the hub, fills that area and then goes thru the outer bearing, and out the front. Takes a lot of grease (half a tube per wheel?), but that is the only way the outer bearing gets new grease to it. A few pumps does nothing for the outer bearing.
Word of caution. Some who have used it have pushed grease thru the inner grease seal and on to their brakes.
If you do it, use a manual grease gun, pump the grease very slowly while constantly turning the wheel (that makes the grease flow thru the inner bearing better and lessens the chance of over pressure on the seal), pump until you see new grease come out the front. I use a hi-temp red grease recommended by Dexter. The red makes it easier to see when new grease is coming out the front, indicating that most all the old grease has been pushed out. Check Dexter service manual for recommended greases.
44,067 PostsLatest Activity: Jun 05, 2026
