AH64ID
Aug 22, 2014Explorer
Larry,
Where did you find info stating to rotate? My manual says no rotation needed.
Also, why do you think the cavity must be 100% full? That is considered overpacked and NOT what you want. There has to be a way for heat to dissipate.
Check the manual and check with Timekn, the procedure you posted is not correct and could lead to early bearing failure.
I do agree with your bottom line thou, just don't fill the void.
44,067 PostsLatest Activity: Jun 05, 2026
