Biggyniner
Aug 22, 2014Explorer
AH64ID wrote:
Larry,
Where did you find info stating to rotate? My manual says no rotation needed.
Also, why do you think the cavity must be 100% full? That is considered overpacked and NOT what you want. There has to be a way for heat to dissipate.
Check the manual and check with Timekn, the procedure you posted is not correct and could lead to early bearing failure.
I do agree with your bottom line thou, just don't fill the void.
Watch this video, same one I posted above. They say these instructions:
1.) Rotate tire slowly
2.) Pump grease in slowly w/ MANUAL pump only
3.) Wait until new grease starts coming out the front (look for color change)
Here is the video from Dexter Axels
44,067 PostsLatest Activity: Jun 05, 2026
