AH64ID
Aug 22, 2014Explorer
The grease will easily get to the outer bearing the shape of the hub will sling it out there when it warms up. If you don't rotate the grease will also only move along the bottom and to the outer bearing without filling the cavity. You really don't want the void filled.
It also appears there is conflicting info from Dexter, as I have read where rotating a dexter is not recommended. Al-Ko does not want rotation with their system, identical with a different name for copyright reasons. They all use the same bearings...
In the end do whatever you are most comfortable with.
44,067 PostsLatest Activity: Jun 05, 2026
