Terryallan
Jan 03, 2014Explorer II
michers wrote:
Just put the stabilizer jacks down. Since you mentioned a TT, most are scissor jacks and rated at around 5000 lbs. I've had to do this myself once for an emergency CG repair and I've also used them to support the entire TT when I repack wheel bearings.
Correct answer. Jus raise the tongue to where you want it. Drop both front stabilizers. Install the jack, and raise the stabs back up.
44,056 PostsLatest Activity: May 04, 2014
