Tarkin75
Aug 21, 2013Explorer
wnjj wrote:
Have you ever considered that perhaps some posting on here are engineers?
Besides, when the GAWR is the sum of both tires, that's not engineering it's just simple math.
Also it's pretty obvious GVWR's of 9900 (just less than 10k used in some laws) and 11400 (just less than 11500 used in some laws) are marketing, not engineering.
These ratings aren't as scientific as some people assume they are.
Also, my experience is similar to Reddog's in that My F150 actually says payload is "with" a specific size and 33psi of tire.
Then when going further, on the Ford website that lists actual specification's for things like the Rear GAWR it also states it is calculated based on "the lowest capacity part" which in my case is the Springs or the Rims. RAWR is 3800 lbs on mine which is coincidentally the rating of the Factory springs at 1900 each. The next lowest part would be the rims at 2100lbs each.
Ford wrote:
(3) Gross Axle Weight Rating is determined by the rated capacity of the minimum component of the axle system (axle, computerselected springs, wheels, tires) of a specific vehicle."
Later
C
44,066 PostsLatest Activity: May 13, 2026
