Tarkin75
Aug 21, 2013Explorer
kohldad wrote:
Ford isn't stating the max of the tire, but the recommended pressure and payload for the vehicle. If you check the tire pressure/load rating table, you would find that is the value.
Ford wrote:
Maximum
Inflation
Pressure (psi)
and
Load Limits
@ Maximum
Inflation
Pressure (lbs.)
That's the table i'm quoting from.
No where does it say "Recommended", and when comparing the "Stats" to some of the other OEM tires, they do line up. Your explanation does sound sound, but it also seems as if Ford could word things a bit better:)
Either way, the numbers aren't always the "rule".
Later
C
44,066 PostsLatest Activity: May 16, 2026
