wintersun wrote:
Payload is a calculation made by the engineers based on the weakest component of the vehicle as it leaves the factory. The calculated figure subtracts 150 lbs. of payload for every passenger seat in the vehicle. Obviously if you only a driver in a crew cab pickup the payload is going to be 600 lbs. more than is indicated on the sticker.
Sorry, dead wrong!:E
The "total weight of occupants and cargo must not exceed" number on the tire loading information label does not care how many people are in the truck - it is the total weight, both people and "stuff" that can be added before the truck capacity is exceeded.
The number is calculated for each vehicle by subtracting the "as-built" or empty weight from the GVWR.
So engineers do not define Payload as such. They design, test and certify a vehicle to meet Federal Standards (including brakes) at GVWR. Payload falls out of the bottom of the equation depending on the truck build configuration. The lighter the truck, the bigger the difference to GVWR, hence a higher payload rating. (within the same GVWR)
To the OP, as Rhagfo suggested, unless your truck is bone stock, your payload rating may be LESS than the number on your label. If you have added anything (tonneau cover, running boards etc) you need to weigh your truck (empty) and subtract that number from your GVWR. That will be your true available payload capacity.
To Wintersun, the number you are thinking of is the old "Reserve Capacity" number, referred to by brholt, that used to appear on the Camper loading label.
This number DID reflect the remaining payload available AFTER there was a 150# bum in each seat.
IMHO the new number makes more sense, especially if there are only a couple of people in the truck.
