RVhiker
Aug 28, 2017Explorer
Atlee wrote:
Jayco claims the cable inlet is good for satellite also. They claim they use RG-6 cable through out.
Haven't tried it, so don't know for sure.donn0128 wrote:
Generally speaking, no. Mfgs use cheap coax and lots of low quality splitters. All of which degrade high quality signal needed by sat receivers.
Maybe Jayco is doing a better quality install of cabling in trailers, but I doubt it. In my trailer (2011) they did use RG-6 cable, but: 1) they used crimp type connectors - not the satellite required (at least for DirecTV) compression connectors and 2) they installed the RG-6 cables with cable turns of as little as 1" radius not the required by DirecTv turns of no less than 6" radius.
I ran proper cable and connectors from a new outside connection. This is not a difficult or extremely technical install.
44,071 PostsLatest Activity: Aug 30, 2026
