dvitale300
May 22, 2015Explorer
Question about slideout lube / maintenance
Hi,
When I have my slide out I spray slide lubricant on the metal rails that are on the top and bottom of the slide. I move it in, then out, then spray again and wipe off anything that dripped not the slide. Is there anything else I need to be doing?
Re the rubber flaps on both sides of the slide. I read that you should spray them with silicone lubricant from time to time.
Is that all that needs to be done?
Thanks
Thanks
