I am thinking you might be thinking different about how to use the solar panels. Running things directly from the solar panels will require alot of panels. The direction of the sun doesnt always give you a constant power output of the panels and of course when the sun goes down you are dead in the water.
What most folks do is have a couple or more of batteries installed like the GC2 6v Batteries in series to give you 12VDC at around 220AHs of capacity. The more the better. Then you will use a small 300Watt to 600Watt PURE SINE wave Inverter to produce the 120VAC to operate your small appliances like the HDTV, DVDs, etc in addition to some other small 12VDC items directly from the battery. Most camping off the power grid gets by pretty good with 220AHs of battery capacity.
Now that you have enough battery power to run all those small appliances and direct connected 12VDC items you want to run you will need a way to re-charge your batteries everyday so you can do all of this all over again the next day/night battery run.
Most folks will re-charge their batteries in the mornings when allowed to run their small 2KW Honda type generator. This is done by connecting your trailer shore power cable directly to the generator 120VAC receptacle using a RV30A-15A long adapter. Using smart-mode charging technology you can re-charge your batteries to 90% harge state in as little as three hours of generator run time. The solar panels really come into play big time re-charging your batteries during the daylight hours when the sun is out. Between the two re-charge sources you should have at least 90% battery state of charge to be able to do the day/night run off the batteries using all your 120VAC/12VDC toys you want to use.
I don't have the solar panels yet but they would be a big asset in keeping my batteries re-charged.
I don't think I would be very successful camping off the power grid with just solar panels. It looks like about 120WATTS of solar is all I would be able to mount on my POPUP trailer anyway. By having the larger battery bank (mine is 255AHs capacity) and being able to run my 2KW generator at 8AM during the morning breakfast meal and then having the solar panels going during the daytime hours would really give me a good solid 90% state of charge on my battery bank. This should allow me to do all these things up to lights out around 10-11PM at night and still run all the necessary trailer keep alive things until 8AM the next morning where I can re-charge my batteries and do it all over again for the next day/night battery run.... This is my camping off the power grid game plan...
There is many ways to camp off the power grid I guess but this method works great for us supporting all of the home entertainment items and my other power Hungary hobby of Amateur Radio operations....
Roy Ken
