SoundGuy
Nov 21, 2015Explorer
speedy72vega wrote:
BTW, what's a Dexter mod?
ZeeLet50 is probably referring to a Dexter Axle Wet Bolt Kit.
The equalizers on most dual axle trailers, probably including yours, use simple nylon bushings that wear out in no time ...
... and once that happens the bolt holes in the equalizers will begin to oval, increasing slop in the system.
If so you'd want to replace not just the bushings but also the equalizers and bolts, just as I did with our previous KZ Spree, but if you catch it soon enough it's possible to replace just the bushings with metal versions and install wet bolts with built in grease nipples. If there's any one mod one might want to consider doing with a brand new trailer this would be it. ;)
44,056 PostsLatest Activity: Mar 02, 2026
