GeoBoy's avatar
GeoBoy
Question for AF 990 Owners
We are seriously thinking about buying a 2016 AF 990 with the side awning but the side awning is located on the drivers side of the truck because the slide is on the passenger side of the truck. Most campgrounds have the utilities on the drivers side of the camper, also most TT's and motorhomes have their side awnings on the passenger side of the truck. So if you wanted some private time from your neighbors you would actually have to drive the truck straight in and then the utilities are on the wrong side. Help!
  • I always thought it was on the passenger side...
    Tried to search some and the few I found were on the passenger side off the slide out..
    I thought the drivers side was another "option" as it is on the side (might be an option for either side??)... and in the brochure it shows in the options as a "Side Box Awning", I assumed it was on the slide out side..
    Waiting to hear.
  • We are seriously thinking about buying a 2016 AF 990 with the side awning but the side awning is located on the drivers side of the truck because the slide is on the passenger side of the truck. Most campgrounds have the utilities on the drivers side of the camper, also most TT's and motorhomes have their side awnings on the passenger side of the truck. So if you wanted some private time from your neighbors you would actually have to drive the truck straight in and then the utilities are on the wrong side. Help!
    It is critically important to remember that the TC crowd does not typically use RV parks or in some cases even campgrounds. TC's work well for boondocking and the awning issue is moot if you are miles from your neighbor. As mentioned previously, I would seriously think through the awning issue especially if you like to stay in RV parks or organized campgrounds where the next site is a only 15-20 feet away.
  • I have a rear awning on my Host. I suggest doing that. I don't think it makes sense to have a slide side awning if it only covers the slide. I suppose it would be fine with a giant awning but TCs don't normally have an awning that is that big.
