agesilaus
Feb 14, 2016Explorer III
Question for the experts
I'm trying to replace the stock steering damper on my 2012 F350 with a Bilstein (along with the front shocks) and despite what I can find on youtube I'm having a heck of a time getting the old one out.
Old damper
New damper
I haven't been able to drive the above fitting out on the truck. You can see on the new damper image what it looks like. There is almost no room to swing a hammer in there. And I don't see any way to use a 'C' clamp. Is there a special tool suitable for this, a bearing puller maybe. Which I don't have and have never used. From what I recall about them tho they would take a lot more room than exists.
Any suggestions are very welcome. Otherwise I guess I'll have to run it down to the local mechanic and let him do it. If the tool coast too much I might to that anyway.
The front shocks are their own PITA, the upper screw has to be removed 1/6th of a turn at a time. And those are hard turns too. I have a combo 21mm ratchet wrench coming in tomorrow that will make that easier there isn't room for a long socket and ratchet wrench. And the long screw doesn't let you use a short socket until the nut is 75% off.
Old damper
New damper
