fj12ryder
Jul 20, 2022Explorer III
Bionic Man wrote:Fixed the link: Inline Fuel Filters.
Just an update. I’ve added a inline fuel filter between the aux tank and the regular filler liner.
I also added a filter on the aux tank overflow tube since they are inexpensive and it seems like the contamination could possibly be coming from that?
The one issue I had is that the one time I left the manual valve open from the aux tank, it did over fill the main tank, probably lost a couple cups of fuel before I saw that. Any idea why that would happen?
Im still considering a spin on type fuel filter but not 100% convinced that it will work with a gravity feed.
These are the filters I’m using now. Filter
I discovered our new-to-us truck already has the feed line hooked up for an auxiliary tank, which makes sense because I believe the guy used it for hotshotting. But the nice thing is he, or whoever, hooked up a nice lighted rocker switch on the dash that operates a solenoid valve for the auxiliary tank feed. So, if and when I get a tank I'll be set up ready to go. Just run the line to the valve, and BOOM done.
