Gdetrailer
Mar 18, 2018Explorer III
NanciL wrote:
Will regular auto antifreeze hurt the seal in a RV toilet?
I am not interested in hearing about RV antifreeze
Jack L
In "theory" and "on paper" it shouldn't.
However.. Auto antifreeze IS extremely TOXIC to not only humans but animals if ingested.
You DO realize that the Auto antifreeze WILL be dumped into a septic system or municipal sewer system which is not designed to break down and process auto antifreeze?
In septic systems that means the antifreeze will eventually make it's way into a leach bed.. While as long as the leach bed is designed and functioning properly it will dissipate over a large area and MIGHT NOT be a hazard..
However if that leach bed is not properly designed or functioning it CAN leach into under ground springs, wells or streams..
Most municipal systems treat the sewage effluent ensuring no unwanted bacteria are left in the waste then eject the treated waste into streams and rivers, they may or may not be treating for auto antifreeze..
Why, oh, why be so darned cheap?
RV antifreeze IS "food safe", while I wouldn't want to directly drink it, it is FDA approved to be used in food processing plants where it may come in contact with food or drink..
44,071 PostsLatest Activity: Aug 16, 2026
