OleManOleCan
Jan 31, 2020Explorer
opnspaces wrote:
Agreed on the quality for a trailer that is going to dunk the warm bearings under water.
If your trailer has the bearing buddy caps then the more expensive seals are hopefully double lip seals which are required. The cheaper seal might be only a single lip seal which will leak with the bearing buddy system.
I even use the Bearing Buddy caps even on my Utility trailer. I have towed my last trailer across a couple of shallow creeks, and thru many places of standing water.
I use Bearing Buddies on all trailers.
