Just press a button to extend your trailer’s awning and enjoy cool shade.
Struggle no more with the opening and closing of your manual awning. If simplicity is king for you, look no further than the Dometic 9100 Power Awning.
The Dometic 9100 Power Awning brings the convenience of a motor-driven awning to the masses. With the simple press of the wall-mounted switch, the durable 9100 opens and retracts with ease. Featuring stylish and rugged vinyl fabric, the Dometic 9100 is the perfect power awning for your coach.
Knee Action design lets the awning fabric and hardware flex in moderate wind to prevent damage, and lets you walk out either end of the awning without having to duck your head. Improved hardware design offers a manual “rain shed” position and pitch adjustment of up to 24" for greater shade control. Its contemporary styling offers radius edges for a sleek appearance.
•The 12-volt motor is tucked inside the roller tube for a clean look and moisture protection.
•The double-sided reinforced vinyl fabric extends up to 8' and is protected in transit by a Polar White vinyl weathershield.
•An excellent choice for travel trailers and 5th wheels, the 9100 Power Awning mounts on laminated sidewalls, using flat awning rail.
•Easy manual operation if power fails. Available in lengths from 10' to 21' with standard or basement Polar White hardware.
Technical Specs
Tech Specs
Weight: 69.1 lbs.
Dimensions: Avialable 10 ft - 21 ft
Documents:
Users Guide
Warranty: Mfr. 3 year warranty.
Manufacturer: Dometic Corp
- See more at: http://www.campingworld.com/shopping/item/dometic-9100-power-awning/34018d#sthash.buX5tXCZ.dpuf
Read it and weep
MM49
