mbloof
Apr 17, 2023Explorer
StirCrazy wrote:mbloof wrote:Sterling1 wrote:
I'm going to replace my 2 lead acid batteries in my Bigfoot truck camper with two 100ah LiFePO4 batteries. I've previously installed a 4 way battery selector switch to allow me to keep one of my batteries at a high enough charge level to start my generator (they are run in parallel). However, this won't be necessary (and probably won't work) with the lithium batteries and I will probably need to have it at the Both position to start my generator.
My question is is can I damage the batteries if I switch to the Both position when one battery is low and the other battery is fully charged?
In a word: No.
A battery is simply a energy storage device.
No matter what "type" or chemistry the batteries are if they have the same nominal voltage (IE: 12V) then the following would be true:
Battery #1 is 12.5V and Battery #2 is 13.5V and you hook them both together in parallel along with a load. What happens?
The load will draw current from BOTH batteries but since Battery #2 is at a higher charge voltage than battery #1 some of Battery #2's energy will flow to Battery #1 until such time BOTH batteries have the same charge voltage.
If you simply hooked a not-so-much charged battery up to a fully charged battery without a actual load the "not-so-much charged battery" would still be a load to the fully charged battery until such time that both batteries have equal voltage.
So can you can see the 'wasted' energy/charge being used for the lesser charged battery?
This is why it is generally recommended that to use two or more batteries in parallel they ought to be the same Brand+type+age+capacity and charge level so stored energy is not wasted charging the other batteries in the bank.
- Mark0.
You're forgetting about the BMS and the electronics in it.
It really does not matter.
Ether the batteries are at the same charge voltage or not. Period.
Don't over think it.
- Mark0.
