SoundGuy
Jan 02, 2018Explorer
roaming_free wrote:
This year we are upgrading our camper, and I just acquired a used truck as well.
My camper is 7250 dry, 8600 gvwr, with a tongue of 900 lbs.
I will be pulling it with a 2013 Silverado 1500 that has the following (in no particular order):
GU6 3:42 rear axle
K5L Heavy-Duty Trailering Package
KC4 COOLING HEAVY DUTY ENG OIL
G80 Eaton G80 locking rear differential
C5W GVW RATING 7,000 LBS
KNP Cooling, external transmission oil cooler
JL4 StabiliTrak, stability control system
MYC Transmission, 6-speed automatic
VR4 TRAILER HITCH WEIGHT DISTRIBUTING PLATFORM
Z82 Trailering Provisions HD
JF3 BRAKE VAC POWER, 17 DISC/DRUM, W/ABS, 7,000 LBS
Is there anything else that anyone thinks that I may not be considering?
WAY too much trailer for a 1/2 ton Silvy, especially with a 3.42 axle ratio. :E I've been towing since 2006 with GMs ubiquitous 5.3L V8 coupled to a 3.42 axle, the first 2 having the older wide ratio 4-spd transmission, my current 2012 having the newer narrow ratio 6-spd. Our current trailer averages ~ 4800 lbs loaded & ready to camp, our previous Spree ~ 5500 lbs, but I wouldn't tow anything weighing any more than ~ 6000 lbs fully loaded with this truck. With a GVWR of 8600 lbs you could easily be running a gross tongue weight of 1100 to 1200 lbs of gross tongue weight, leaving very little payload capacity to account for the weight of everyone and all cargo in the truck when you're towing. :( You need a properly equipped 3/4 ton to tow a trailer this size.
