APT
Mar 15, 2015Explorer
krobbe, was the 8.1L available for 2000? The tow ratings would be about 7500 to 12000 pounds depending on engine and axle ratio. If the 6.0L, then 7500/9500 for 3.73/4.10 axle. You'll want to stick to under about 6000 pounds dry with the 6.0L. If you have the 8.1L, then 8k dry should be fine.
Flush all the fluids. Replace the receiver. Get a proportional brake controller. Use a WDH with integrated sway control.
44,068 PostsLatest Activity: Jun 10, 2026
