Bedlam
Jul 11, 2016Moderator
If when loaded with fuel water and supplies you are approaching 7000 lbs on the rear axle, it's time to consider going to 19.5" tires and rims. If you are around 6500 lbs, there are plenty of 18" wheel combinations that will still allow you to tow.
If the the truck has the upper overload spring, you should just need the upper and lower StableLoads to carry 7000 lbs on the rear axle. If you don't have this upper overload, you probably also do not have the rear stabilizer bar - These will be the first things you want add before making further changes.
