Vinsil
Jul 13, 2016Explorer
mkirsch wrote:
It's a 2015 with a 6-speed transmission, so your rear axle ratio is effectively a 4.10 if not 4.30. I would not worry about it. Let the engine wind up.
Not sure if Ford does this like Ram, but my 6 speed isn't geared much lower than a traditional 4 speed, the fifth and sixth gears are effectively double over drives giving better fuel economy.
I do agree, let the engine work in the upper RPM range as its a small block with overhead cams, it makes power up top. But pulling heavy you might never see fifth or sixth gear.
As the OP said, learning experience to his next truck. :)
