wuli959
Jul 16, 2016Explorer
Vinsil wrote:
See that hole on the bottom leaf? Bolt some stableloads in there.
The photo above was of the springs with 80 PSI in the airbags.
Doesn't need another leaf (or something) to hold the weight with less PSI or keep using the airbags at 80 PSI and add stable load to help engage the springs at the same time?
(Not even sure if I'm asking the right question)
This is what the spring looks like with 10 psi in the air lift bags. Pretty flat with a downward tilt front to rear (truck)
