Bedlam
Aug 04, 2016Moderator
jimh425 wrote:SoCalDesertRider wrote:
You need to decrease the air bag pressure and keep the truck firmly planted on the overloads.
You can make this contact happen if you use airbags to raise the rear by extending your bump stops. I use Energy Suspension ones. There are other options as well.
I've used both the Energy Suspension and StableLoad pads. The ES pads compress to half their height and the SL pads compress very little. See how much room you have when unloaded and use the SL's if you have 3+".
