bobinyelm
Oct 13, 2014Explorer
Ah, so you don't even winterize by pumping pink stuff through all of the water lines, but just allow the lines to gravity feed down to the toilet flush line and back to the fresh water tank, and have had no problems? Nice to know!
I had advised them to bypass and drain the HWT through the anode, and to use a winterization kit (if not present) to suck-up and circulate pink stuff through all the water lines. (Someone said AFs leave the factory w/ the winterization valve already)
They WILL be checking on it periodically, I suspect, so pink in the traps will probably be OK. By "unused," I meant not used for camping.
I did advise them to remove the batteries and store them charged in their apartment.
