FishOnOne
Dec 30, 2014Nomad
otrfun wrote:
My next truck (4x4, CC) has to have a minimum 3000 lbs. of payload. That leaves me with either a 1 ton diesel (3500-4000 lbs.) or a 3/4 - 1 ton gasser (3200-4000 lbs.).
I've run my gasser vs. diesel numbers as far as purchase price, MPG (towing & empty) and resale.
I'm familiar with what's needed to maintain a gasser; however, never owned a diesel. Here's what I know, don't know, about diesel maintenance:
1. Oil costs are approx. double vs. a gasser due to twice the oil capacity.
2. Oil filter. I assume these cost a bit more than a gas oil filter?
3. Fuel Filters. Assuming DIY replacement, what can I expect to pay for filters? How often?
4. DEF. 2-4 cents of DEF used per a gallon of diesel??
5. Valves. Under normal operating conditions is adjustment ever necessary? If necessary, cost?
6. Injectors. Under normal operating conditions is maintenance/replacement necessary? If necessary, cost?
Other diesel specific maintenance items I may have overlooked?
Thanks!
1.Oil: I agree with your estimate
2. Oil Filter: Yes they cost a bit more than a gasser due to there physical size is bigger
3. Fuel Filters: Cost really depends on brand. I pay $70 for filters and change them ~20k miles. The Duramax can go much further on fuel filters.
4. DEF: Depends on how you drive the truck. I notice that DEF consumption is more during the hotter months and when I tow so DEF consumption varies and varies by brand too. I believe the cummins uses more DEF than a Duramax or Power Stroke.
5. Valves: Cummins required valve adjustments. Duramax and Power Strokes use hydraulic lifters there they don't require adjustment.
6. Injectors don't require any specific maintenance or adjustments. You can run a diesel fuel additive from time to time just to keep the injector clean.
